Question about Hoover Washing Machines
Washing machine dynd9144d3x shows e4,what part do I need to fix it
Shows e4 problem
3 Suggested Answers
Anonymous
  • 4 Answers
SOURCE: When my Samsung Sensor Quick P801 800 washing
The machine can't balance the weight of the cloths.
Posted on Dec 18, 2009
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: Wats this problem showing on display e4, e7 in Toshiba washing machine.
Toshiba AW B1100GM User Manual
like 98 % of questions on here,there is NO info,we like to help,but,it makes it frustrating when someone only gives us a little info,like we are supposed to be mind readers,I don't know where the info posted to if it was posted at all,so,like all the others,my guess is just that,here is a manual to look through
Posted on Apr 09, 2015
cocothebean
Coco the Bean
  • 457 Answers
SOURCE: AKITA washing machine does not spining why?
Fan belt may have snapped!
go to there website and see if they have instructions on how to open the front of the machine to get to belt.
Posted on Aug 08, 2015
I have a LOFRA dishwasher LOD6001/LOD60002W showing an E4 error. It started OVERFLOWING so I opened the door to turn it off. Now it will not restart.
"E4" means Error and from 1 to 5 means malfunction in water valve / sensor. E4 means defective water level sensor.
Sep 27, 2018 | Dishwashers
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4. I press the program button, i select the washing program i want, but on the display the error code "E4" is being blinking. How do I fix it please?
The E4 Dishwasher Error. According to the manufacturer the E4 error will be given if the vent for overflow when water level exceeds the set level overflow water triggers the lower float, terminates operation and gives E4 warning.
Clean the level sensors.
May 15, 2016 | Dishwashers
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
Error e4
someone activated 4 zone reset thermostat
Jul 11, 2013 | Coleman York Control Board 03101237000...
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
E4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
Nov 29, 2007 | Uniden TRU9485 Cordless Phone
Washing Machines Logo
37 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
