Communication error has occurred between the RADF and the scanner.
(1) Check if the harness connecting the RADF board and SLG board is disconnected or open circuited.
(2) Check if the conductor pattern on the RADF board is short circuited or open circuited.
(3) Check if the conductor pattern on the SLG board is short circuited or open circuited.
(4) Replace the RADF board.
(5) Replace the SLG board.
SOURCE: How to fix problem error code c550 in Toshiba 305
paper remaining jam in the path in transport. check and clear
SOURCE: Toshiba e 233 is error code E550 what problem sir
Code E550 Description Paper remaining jam on the transport path: The paper is remaining on the transport path when printing is finished.
SOURCE: Toshiba e 233 is error code C410 sub error code 1 how to clear this problem
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
