Music Logo
A
Anonymous Posted on Jul 17, 2016
I'm using FL 1on my windows 8...though I m not able to detect my Casio ctk-810in when I connect it via usb midi slot
5 Related Answers
Michial Gueffroy
  • 1140 Answers
  • Posted on Apr 23, 2009
SOURCE: Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 09, 2009
SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Fred Yearian
  • 5603 Answers
  • Posted on Oct 07, 2009
SOURCE: casio ctk 700 Fl studio 8 connectivity
Fruity Loops version 4 requires Windows up to version XP.
If you happen to have Vista on your PC, you should probably retrofit to XP as there are MANY compatibility problems with Vista and a lot of the special purpose software.
First thing is to COMPARE the PC requirements against what Fruity Loops says it requires.
Anonymous
  • 192 Answers
  • Posted on Feb 10, 2010
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
Fred Yearian
  • 5603 Answers
  • Posted on Jan 04, 2011
SOURCE: I can´t find CASIO CTK-810
Vista has SO MANY compatibility problems that it MAY be futile to try finding a specific driver for thaat synth. Consider going to Windows 7. HOWEVER, a MIDI driver is a MIDI driver and anything specific to the synth is really not truly just a driver as such, but a user interface type program that may contain things like voice editors and other functions specific to the synth.
Usb driver casio ctk 810IN for windows 7
Both 32bit and 64 bits drivers for Win 7 & Win 8 have been made available at
http://support.casio.com/en/support/download.php?cid=008&pid=20
2answers
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Ctk 810in usb midi driver for windows 7 32 bit
Casio has this driver on their support page: https://support.casio.com/en/support/download.php?cid=008&pid=20 . Scroll down to the drivers section and click on the link for Digital Keyboards/Piano (excluding PL-40R) for 32-bit OS versions. This link is to the left. Currently the link for the 32-bit versions of Vista, Win7 and Windows 8 is https://support.casio.com/en/support/download.php?cid=008&pid=75 .
I hope this helps.
Apr 13, 2013 • Music
I need to know from which sites can I download rhythms & tones which is compatable fpor my casio keyboard ctk 810IN
You can play back standard MIDI files from the SD card slot, or load them into memory via USB. However, it is not possible to add new tones or rhythms.
1helpful
1helpful
Casio ctk 700 Fl studio 8 connectivity
Oct 06, 2009 • Casio Music
3helpful
3answers
Not able to connect to USB MIDI of my Casio CTK 810i
1helpful
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
3helpful
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
