The TV is wall mounted and the table stand which was supplied when orginally purchased is now missing. I need to source a replacement stand do you have any suggestions of possible suppliers.
Good luck with that. As soon as these sets go out of production, so do most of the parts associated with them. You would be better served to get a TV table stand that uses a wall-mount-style backer. That way you get the tabletop mount and the extra security of knowing it won't get knocked over easily. Something like this....
Universal "Jimmy stand" for just about any TV available at Walmart or other places. They're 70 to 90 USD though. They include wall mount or a base to set the TV on a table or other surface. Search
sj-Stand-3755BB If you have parts missing on the manufacturer's one, good luck finding those, they typically come as a unit.
You can get to find alternative mounting by visiting any hardware store. Please find some tips from the link below with which it can be mounted to be fixed on the table or rack.
1. Disconnect all cables. 2. Cover a level and stable surface with a thick and soft cloth. 3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge. 4. Rotate the cable holder 90 degrees, and pull it out completely. 5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw. 6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit. Hope this helps! Thanks
Smith.
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
