Seems to be a broken tube, but there is no access from the front for inspection/repair. Any tips how to proceed?
Remove the soap drawer completely. They usually pull straight out after overcoming some resistance at the end of the normal travel.
The problem you have is usually caused by a buildup of soap residue blocking one of the drains from the soap compartment to the wash tub. Clean all traces of residue from the drawer and the inside of the compartment and then pour water into the drain(s) to check for blockage(s).
Sometimes the top panel of the machine must be removed to access the hose(s), for removal and rodding through but often it is possible to clear them from the soap compartment using something flexible of a suitable size.
Testimonial: "Thanks for your advice. However, the water seems to pour out ON THE TOP of the slide for soap drawer and seems to be leaking somewhwere else than the tube/connection. I have removed the top panel but cannot get the water feeding slide unit out for further inpection/repair."
