The following should help your memory.
Regulating the length of the stitch: The machine can be adjusted to from six to thirty stitches per inch, as indicated by the numbers on the stitch indicator plate. Changing the length of the stitch is accomplished as follows: Loosen the stitch length stop control (B, Fig. 12) and move it to the bottom of the slot. Move the stitch length lever (A, Fig. 12) to the desired stitch length. Now, move the stop control up until the control plate (visible in the stitch length slot) touches the bottom of the stitch length lever. Tighten the thumb screw (B) with finger pressure only. At this point, the stitch length is "marked," and you can move the lever up to sew in reverse at approximately the same stitch length, and then return it to your desired forward length.
If wrong instructions <?>, find your model... http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html
How close the stitches are to each other? Stitch length?
There is a stitch length selector on your sewing machine. The owner's manual is the best source for information. Technically, the stitch length selector increases the movement of the feed dogs. The feed dogs pull the fabric under the presser foot. Increase the stitch length, the feed dogs increase movement and pull the fabric through faster.
The stitch length lever/dial should control that for you. Consult your owner's manual. If it is not changing the stitch length even though you've adjusted it, then it probably needs service.
Mar 3, 2015 - The majority of sewing machines indicate stitch length in millimeters. A 2.4 stitch length means each stitch will be 2.4 mm long. ... When you adjust the stitch length, it's not the needle that is changing, it's the feed dogs (those ...
? 2:40
https://www.youtube.com/watch?v=YqwHtYpKBzo
May 31, 2011 - Uploaded by HowcastArtsRec
Learn how to select stitch length when using your sewing machine for ... also not so small that it will take forever to get through your machine.
Your tension shouldn't need changed when you change the length of the stitch. Start at C-D for a start. Use rags to test. Your stitch length is chosen by the slide handle on the bottom. By moving to the left your length of stitch will increase and opposite will decrease the length. Anyway, your tension for the fabric may need to be set with a test piece. After that your chosen length shouldn't need any change of tension.
The straight stitches can be shortened and lengthened utilizing the length selector. If you are attempting to do this with zigzag the stitch will be the same distance but the fabric will appear as if the material hardly moves. This will be changed by using a wide stitch. If you can't truly get a different stitch length on the straight stitch you may need the feed dog adjusted by a pro so that it will give you a longer stitch.
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
