Electrical Supplies Logo
Posted on Jul 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove the starter motor from my Honda G400 electrical generator?
Is an exploded diagram of this generator available?
The Vanguardian
Level 3:
Master:
  • Master 531 Answers
  • Posted on Jul 18, 2016
The Vanguardian
Master
Level 3:
Master:
Answers
531
Questions
0
Helped
180685
Points
2974
If people could just learn to GOOGLE their questions...
Honda G400 Type VIN G400 1000001 1096409 Small Engine Parts
This is on the same website, it's for serial number G400-1200001-1519048, Honda calls it G400K1
(sorry, Fixya doesn't give me the option to set this as a link)
Either search on that website for Honda G400K1 or drop the following into your address bar.
http://www.ereplacementparts.com/honda-g400k1-type-qb6vin-g40012000011519048-small-engine-parts-c-37657_37658_37986_37705.html
  • 1 more comment
  • fbockhorst Jul 19, 2016
    Mine is a later serial number (G400-1295117). What differences should I expect on the exploded diagram. Thank you very much!
  • The Vanguardian
    The Vanguardian Jul 19, 2016
    I added information to my original answer. Please see that.
  • fbockhorst Jul 20, 2016
    You are a hero. Thank you
1helpful
I've a Honda eu3000is generator, new carb, new starter. It will electric crank but not start but I can pull start it.
it seems like your ignition switch may not be removing the ground while in the starting position try removing the ground wire from key switch if it turns over and start with key replace switch assy.
Electric starter will not work on honda e u 3000 generator
Hi there! 1) Check battery with a load tester and recharge / replace if necessary 2) Check the ignition switch for loose wires or if the switch is okay 3) Remove the starter and try to run it against a piece of wood ( Have you seen the wooden hammer handle of an auto electrician?) If you can stop it then the motor needs repair/replacement it is often cheaper to replace than repair it excluding labour!! 4) Check ringear on the flywheel and the pinnion of the starter motor for binding and wear. Keep these tips in mind for your Automobiles too
How do i remove a 1982 kawasaki kz 1000 starter motor
Follow the specific instructions in the Factory Service Manual. Step 1 - Remove the heavy wire from the starter solenoid. Either end will suffice. Step 2 - Remove the chrome cover over the starter. Step 3 - remove the screws that hold the starter motor in place. Step 4 - Lift the starter motor out of the engine. NOTE: removing the carbs may make this step simpler. The "business" end of the starter should come out of the splined starter clutch gear. If you have trouble removing the starter from the clutch gear, you may need to remove the left side stator cover to gain access to the starter clutch and chain. The exploded parts diagram is available HERE Kawasaki Motorcycle Parts 1982 KZ1000 J2 STARTER MOTOR STARTER CLUTCH...
Honda ES6500 blows 15amp fuse as soon as the key is turned to "ON" tested starter with a jumper wire, works fine. Took the control box apart found nothing unusual. Removed ignition switch found...
hi
I think the problem is on when the key is turn to rotate and to engage the starter motor and it at this point that the cable curring the current on to the starter motor it then the fuse gets blown , in my opinion this cable is shortening across the chassis causing the fuse to blow, or when it get to the starter solenoid a faulty solenoid absorbs accessed electric current causing the fuse to blow
Where is the location of the starter on a 1999 bonneville se and is it hard to take off yourself?
REMOVAL & INSTALLATION
(see Figures 2, 3, 4, 5, 6 and 7)
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely.
  3. If necessary for access, remove the splash shield.
  4. If equipped, unfasten the flywheel inspection cover bolts and remove the cover.
  5. Label and detach the electrical connectors from the starter.
Fig. 2: Unfasten the starter motor electrical connections. You may want to tag them first to avoid confusion
Fig. 3: Exploded view of the starter motor electrical connections
  1. It may allow more room it you remove the right side cooling fan.
  2. Remove the starter-to-engine bolts, then carefully lower the starter from the vehicle.
Fig. 4: The starter is attached to the engine with 2 mounting bolts (see arrows)
Fig. 5: Unfasten the front mounting bolt (1) and remove any necessary shims (2), noting their locations for installation
Fig. 6: Unfasten the long starter mounting bolt, then remove the starter motor from the vehicle
Before installing the starter motor, make sure the electrical terminals are secure by tightening the nuts next to the cap on the solenoid battery terminal and on the "S" terminal. If these terminals are not tight in the solenoid cap, the cap may be damaged during installation of the electrical connections and cause premature starter failure.
Fig. 7: Exploded view of the starter motor mounting - 1987-97 vehicles
To install:
Note the location of any shims so they may be replaced in the same positions upon installation.
  1. Place the starter in position, then install the starter-to-engine bolts and tighten to 32 ft. lbs. (43 Nm).
  2. Attach the electrical connectors to the starter, as tagged during removal. Tighten as follows:
    1. Tighten the nut on the solenoid battery terminal to 12 ft. lbs. (16 Nm).
    2. On the SD-250 and SD-255 models, tighten the nut on the "S" terminal to 22 inch lbs. (2.5 Nm).
  3. If removed, install the flywheel inspection cover and secure with the retaining bolts. Tighten the flywheel cover bolts to 62 inch lbs. (7 Nm).
  4. If removed, install the splash shield.
  5. Carefully lower the vehicle.
  6. Connect the negative battery cable.
Hope helps (remember rated and comment his).
How do i get the instructions on how to replace a starter for an 1989 pontiac bonneville
To install:
Hope helps (remember rated and comment this).
2helpful
Where do I find the starter for my 1997 buick lasabre - I need to replace this part.
To install:
  1. Place the starter in position, then install the starter-to-engine bolts and tighten to 1 ft. lbs. (43 Nm).
2helpful
I am need of a starter for a Honda RV generator EV 4010. Where is the starter located on the EV 4010? What do I need to remove on the unit to get at the starter?
ELECTRIC START WILL BE MOUNTED BETWEEN THE POWER UNIT AND THE GAS MOTOR IF YOU TAKE THE OUTER COVERS OFF YOU SHOULD BE ABLE TO SEE IT IT WILL LOOK LIKE A MINI CAR STARTER IF YOU NEED MORE HELP I MAY BE ABLE TO GET SCHEMATICS FOR YOU BUT I WOULD NEED MOTOR INFO MODEL BRAND SERIAL #S AND FROM THE POWER UNIT ALSO
Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Starter replacement
89632p02.gif Unfasten the starter motor electrical connections. You may want to tag them first to avoid confusion
89632g34.gif Exploded view of the starter motor electrical connections
Click to Enlarge
89632p03.gif The starter is attached to the engine with 2 mounting bolts (see arrows)
89632p04.gif Unfasten the front mounting bolt (1) and remove any necessary shims (2), noting their locations for installation
Click to Enlarge
89632p05.gif Unfasten the long starter mounting bolt, then remove the starter motor from the vehicle
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
