I'm looking for 4 digits code to set up remote URC for TV lodgingstar, the one they provide 3147 does not work and i have been tried with almost codes of RCA, Samsung too but no chance
SOURCE: rca universal remote code
hi,
I've lost my code list for my rca universal remote...my remote is a rca and my tv is rca can you please help me but i can't change my tv so i can watch my movie on my dvd i don't know how to swicthing over to the input so my dvd can play.
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Here are the GE TV codes provided in the manual: 0047, 0051, 0451, 0178, 1147, 1347
To Program the Remote follow these steps:
1. Turn on a desired device you GE TV.
2. On the remote control, press the TV key once
3. Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until you find one that works.
6. Repeat steps 1 through 5 for each device you want to control.
Here is a link to a pdf. of the Remote's Manual:
http://www.retrevo.com/support/One-for-All-URC-3021-Universal-Remotes-manual/id/2784bh227/t/2/
Hope this helps
