There is an error message b200. I cleaned the print head with no results. print carriage does not move
1) Turn the printer off. Unplug it from the power source. Open the printer cover in order to expose the ink cartridges.
2) Remove the MP560 cartridges - PGI-220BK and CLI-221. Re-install the printhead, and the ink cartridges before you power up your printer.
3) Cleaning the printhead might solve the problem.
SOURCE: LCD message: CHECK INK TANK
Please check the solution posted in this
http://www.fixya.com/support/t145742-printing
I'll think of something
SOURCE: Can you help? After changing
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing
If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning).
Note:
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
Print Nozzle Check Pattern
< 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
Print Head Cleaning:
Deep (Print Head) cleaning:
Note:
Do not do any other operations until print head cleaning is completed.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
Note:
Do not do any other operations until print head deep cleaning is completed.
Note:
If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
SOURCE: We installed a new Canon black ink cartridge and
Hi there
Take out the print head and just gave it a good clean and put back in.
All the best Pineworks
