Need to tune sky remote to use with new tv, need code
SOURCE: sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
SOURCE: Sky remote handset will not operate mute. volume etc.
Go to interactive
Select Number 5
Then select the remote option (5) You will then get a list of tv models with codes, follow the directions on screeen
SOURCE: code for sky+remote control for lg tv 50pc56
1293 worked for me. But here are some more
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318,
0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes;
206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502.
The codes are stored in a database of the Sky remote. If the above codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes. Best regards, LG Electronics.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
SOURCE: no instructions for a goodmans remote
there are a few numbers for a goodmans tv (the codes are for gemini 6 in one)they all enter 3 digits
002 004 009 027 028 051 068 093 111 115 127 153 169 171
hope that helps
