SOURCE: RICOH Photocopier machine - problem
The code you are getting is actually E-101 there is not enough space on display to display the whole code so in future if you get a code again press the # key and you can see the whole code .This code is an exposure lamp code , so either your exposure lamp is blown , or got lose connections , or you moved the machine and the scanner klimed off its rails and cant go back to the hime position .Try to enter the service mode by pressing yellew c 107 and hold down blue c all in sequence ,the number 1 will star to flash , press 5 then # 810 # then 0 # switch on and of and see if it works other wise send me a reply and ill see how i can help you .thanks
SOURCE: Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
SOURCE: i have a problem with canon ir2016j photocopy
you have to upgrade and install system software tool (SST) in the copier.
My problem c3451
