Tappan 30IN ELEC IGNa Oven Logo
Posted on Nov 19, 2007
Tappan Electric Oven
Need instructions on how to set for self cleaning. Set the over knob to clean and latched the door....nothing happened. Does the thermostat need to be turned up all the way?
  • 7 more comments
  • Anonymous Nov 30, 2007
    I have a Tappan Electric Range with Top and Bottom Ovens. The bottom
    oven is self-cleaning; however, I have never cleaned it, but it is needing to
    be cleaned now. I have lost my manual that would give instructions on the
    procedure to follow to set the self-cleaning oven process. Would you please email these instructions to me; of advise of a telephone number I
    could call for these instructions. My email address is:
    [email protected]
    Thank you!
  • Queen v Mar 24, 2008
    Do not have manual for Tappan electric self-cleaning oven - one knob is at clean and door is locked but how do I get it to start cleaning now???
  • oven problem Jul 16, 2008
    I set the self clean cycle on both knobs and the door locks, but nothing happens. Please help
  • mlwhitfield1 Aug 04, 2008
    When I push the self cleaning button, I get --- then it goes back to the time. Help
  • cfunk29 Oct 25, 2008
    I'm trying to clean my oven as well. The locked light is on and the knob is set to clean. Now what?
  • sburgess997 Feb 02, 2009
    I do not have the cleaning instructions for an electric glass top oven. model# 31-5592-18/01
    I need to find out how to operate the self cleaning of the oven.
    any help?
    Thanks
    Sammi
  • Jennifer Beeson May 11, 2010
    How to use the self clean on electric Tappan oven
  • Anonymous Mar 18, 2014
    how to instructions
  • Anonymous Mar 28, 2014
    has 6 knob controls and electronic panel in middle
brwneyz
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 18, 2008
brwneyz
Contributor
Level 1:
Answers
Questions
0
Helped
1414
Points
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
[email protected]
Anonymous
Level 1:
  • Posted on Nov 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1414
Points
Lost cleaning mannual for school equipment....have removed interior racks and set both dials to 'clean'...problem is how long should I have it on the clean cycle or does it automatically turn off? (not using clocks)
Thanks, Bheideman
A
Anonymous
My stove will not stop opening and closing. I have no idea what is wrong with it.
1helpful
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 • Ovens
1helpful
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
How to self clean a 1989 model self clean GE oven How do I set?
I found that you cannot turn the CLEAN knobs both off before you release the latch on the door. You cannot unlatch the door
if the Oven Set knob is turned from Clean to Off.....it must still be on Clean to unlatch....simple, huh? Well, it was confusing
at the time!
Dec 01, 2009 • GE Ovens
1helpful
Oven door is in the locked mode and wont close
You can use a screwdriver and a wire coat hanger to get to the latch between te slots on the door. you have to open the door to get to the scews in most cases.
14helpful
2answers
Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Nov 10, 2008 • Ovens
JTP56 Self Cleaning issue
It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
Thanks, Mike
Oven door won't open after self cleaning
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
8helpful
2answers
Self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
5helpful
2answers
Tappan electric stove designer series
the cleaning light and the lock door light doesn't go on when I set them to self cleaning and lock the door what should I do
142helpful
10answers
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Top Tappan Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
Are you a Tappan Oven Expert? Answer questions, earn points and help others
