Machine runs fine when Choke is fully out. Will sputter and chug when choke is in, This is while mower is engaged & or when mower not engaged but just driving.
Carb needs cleaning and possible rebuild. Very common problem especially with ethanol gas.
Sounds like the float is sticking or the needle is clogged. Neither one should happen on a clean ebuild unless there is trash in the fuel lines. My local shop charges $65 for a rebuild. Alot less than a new one. I would drain the tank and change the filter and have the shop that did the rebuild fix it...something is wrong with the rebuild.
Carb was recently cleaned.. Wondering if it may need rebuild, I was hoping it was a filter or fuel pump issue.
Carbs expensive for a Lawn Tractor of this model?
Carb was just cleaned apparently. I was hoping it was a Filter or Pump issue.. Are carbs expensive for models like this?
