Question about Epic View 550 Treadmill
How do you change walking belt on Epic View 550
Walking belt needs replacing, how do I get old one off?
    Top Expert:
  • 11,573 Answers
Heidi, There will be quite a bit of disassembly required to remove belt, I have attached your manual, which shows an exploded view showing what has to be removed to access rollers and remove belt. you may get away with dissembling/remove front motor cover,remove rear roller and front roller.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/d/de84f386-3308-4d84-a2ed-a52898e55aa5.pdf
Treadmill Walking Belt Installation Video by Treadmill Doctor
How To Remove Replace Treadmill Belt and Deck Green Fitness Company
Posted on Jul 24, 2016
Anonymous
SOURCE:
How do I replace DRIVE BELT MOTOR AND WALKING BELT for Epic treadmill view 550, Model EPTL99609.0 ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 01, 2016 | Epic Exercise & Fitness
Everything works on the display but when you start the track it doesn't move. If you start walking on the track it will dsiplay your speed but not run by itself
Remove the front cover and check to see if the RED led is solid.
4 x screws on the front and two underneath the belt to the sides.
Sep 10, 2011 | Epic View 550 Treadmill
The belt on the Epic 426 MX treadmill sticks when walking on it.
Dear Sir:
I will try to help you:
1.
Slow Walking Belt
o 1
Check that the surge protector meets the specifications listed in the manual.
o 2
Remove the key from the console.
o 3
Unplug the power cord.
o 4
Turn rear roller bolts 1/4 turn counterclockwise using an Allen wrench.
o 5
Keeping the walking belt centered, you should be able to lift each edge of the belt 2 to 3 inches.
o 6
Plug the power cord back into the surge protector.
o 7
Reinsert the key into the console.
o 8
Repeat the process if, after the treadmill has run a few minutes, the walking belt is not properly tightened.
2. Walking Belt Slips
o 1
Remove the console key.
o 2
o 3
Follow the same steps used for a slow walking belt.
See the videos:
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
With this you will fix it.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Feb 07, 2011 | Epic 425 Mx Treadmill EPTL88105 !
Hi my belt is slipping. I have tightened it but it is still slipping. I am concerned that further tightening will result in a too high amp draw on the motor and cause a burn out. Does the deck needs to be...
Does the belt stop while walking or running? Does it staop after it has run for a while? Does the motor seem to stop too? or can you hear it running like normal?
Let me know, It is most likley the pully on the front roller.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 08, 2010 | Epic View 550 Treadmill
I am trying to take the motor cover off to replace the motor belt. I have removed the screws in the back panel, but the cover still appears to be in a bind and I cannot find any other attatchments in the...
There are 2 more screws located on the bottom side of the cover. You will need to fold the treadmill down to the ground, console should fold down on top of the walking surface. This will expose 2 holes close to the front roller bottom. These screws are phillips head and need to be removed as well. This will free your cover allowing you to remove it.
Aug 24, 2010 | Epic View 550 Treadmill
How do I remove the cover to replace the motor belt?
There are 3 screws across the back of the cover and then there are 2 more screws located on the bottom side of the cover. You will need to fold the treadmill down to the ground, console should fold down on top of the walking surface. This will expose 2 holes close to the front roller bottom. These screws are phillips head and need to be removed as well. This will free your cover allowing you to remove it.
My epic T60 will go great for 10-15 minutes and then
These treadmills have what is called a thermal switch. It is designed to shut the machine off if it gets too hot. To help this problem you can purchase some treadmill lubrication. It is a waxy based substance that you put on the underside of the walking belt. That is the most inexpensive alternative. You may need to purchase a new walking belt. How you can tell if yours needs to be replaced is to put your hand on the underside of the walking belt. You should feel a texture like a screen door if it is in good condition. When you pull your hand out it should feel like you have been eating popcorn, a little greasy. This will prevent the overheating problem and not shut your machine off in the middle of workouts.
Apr 05, 2010 | Epic Overstock T60 Treadmill Treadmills
Epic View 550 Treadmill Logo
893 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
