I downloaded one excel file through my gmail. And when I tried to open that file one error is coming. That is Excel can't open or save any more documents because there is not enough available memory or disk space. But I have memory and disk space.
SOURCE: windows excel file can't open
From Excel, try clicking on the 'down' arrow in the 'Open' button, then select, "Open and Repair," then select the file.
SOURCE: "Not enough memory to run microsoft excel."
it is conflicy with win xp updates.
check your ram.
go to device amanger then advanceced increase your virual memory to 1.5 *your rammmeory.
SOURCE: MS Office 2003 Intallation
Go to "FILE", "Save As" and then change "Save As type to XLS" That should hold that setting afterwards from now on.
<img src="http://i.i.com.com/cnwk.1d/i/tr/downloads/images/10_things_office2007_compatibility/10_things_office2007_compatibility_a.jpg">
If you have any more questions please feel free to email me and don't forget to rate.
Thanks!
SOURCE: When I try to open a word doc. or excel document
you have to right click the file (word doc. or excel doc.) and select "open with". A window will appear that allows you to choose which program will open this file. Select word for the word docs and excel for the spreadsheets and select the option to always do this for these files types. Once the default program has been set all other files with those extensions will now open with those programs.
Good Luck and Please Respond to this post!!!!!1
Rate Fixya if the problem was solved!!!!! :D
SOURCE: I was using gmail; opened excel file; made changes and saved now i can't find the document. Help!
If you clicked "Save" not "Save As", the file is likely in your temp files somewhere.
The method to find the file is tedious - but if it is on your computer - this will find it.
Click Start>Search for Files or Folders and then under the When Was it modified - put in the date range for when you saved the file.
Next - in All of Part of the File name type: *.xlsx
Next - In Look In - make sure to choose the whole C Drive.
Next - In More Advanced options, make sure to check the System Folders, Hidden Files and Folders, and Subfolders.
Then click search.
If the Excel file is on your computer - this search should locate it.
It is because your excel file is get corrupted. There are several reasons of excel file corruption; virus attack is main reason of corruption. You can fix this problem with the use of "open and repair" utility of MS excel or you can use Excel repair tool http://www.stellarinfo.com/excel-recovery.htm .
