Whirlpool WTW6400SW Cabrio Washer Logo
Cesino Smith Posted on Jul 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lock isn't catching on my washer I have a whirlpool cabrio top loader
deton8 von Splosion
Level 3:
  • Whirlpool Master 3,342 Answers
  • Posted on Jul 27, 2016
deton8 von Splosion
Whirlpool Master
Level 3:
Answers
3342
Questions
6
Helped
927386
Points
54123
Hello Cesino Smith,
It is my BEST advice to get your GENERIC part number off of your ORIGINAL PARTS LIST... (TOP LATCH item #29 )
Contemporary internet (SEARS) WISDOM says your part... #29 on your parts listing diagram (top latch) WPW10619844... THEY SAY "It appears your part number is no longer available"...
I say... They are wrong...! At the bottom I have listed more options (on-line parts suppliers)... Bountiful on eBay...!!
It is a VERY POPULAR part... (read: serious problem area).
You need to talk to these listed parts houses (below)...
This is a difficulty 2 (pretty easy)... job... AND there is a GREAT VIDEO on the appliancepartspros.com (first URL at the bottom).
Your latch connects inside the control pod at the top of your machine... (opens from the back)
The top is hinged at the back & held by SPRINGS in front.
It is NOT as easy to coax the TOP OPEN.. as the video depicts... but if you have patience ... (pulling up one side will lock the other COMPLETELY... When you finally do get it open put a little Vaseline on the front side (it will reduce the brute force require to press the top back down into place (and slow the RUST).
Your average PROFESSIONAL would just walk up and
rip the top open with a giant tug... Most times that will work... but there's the possibility of BREAKING the SPRING STEEL clip
(two) on the front of your washing machine...
(of course if they were working on their OWN machine
they do it the following way:
At about 5 1/2 inches in from each corner are spring clips
that hold your top down. wrap the tip of your PUTTY KNIFE with masking tape (to protect your appliance finish) ...
If you have an assistant ... it would be great to push both springs and lift the front
The "TYPICAL" price of your part (NEW) is around $60 to $80
PURCHASE... (rated EASY to replace)...
If you can un-plug the machine...
Have a putty knife & some masking tape...
You can check this part yourself... and not damage your beautiful finish in the process... tape your door closed before lifting the to... else you risk breaking EXPENSIVE things (possibly fingers).
According to most my generic part numbers (my opinion) ... my Kenmore Elite (110.28082700) is really a Whirlpool... Part W10059230... IS the SAME as your WPW10619844
While I don't ordinarily (ever) recommend SEARS for anything but a pain in the posterior... Their parts are GETTING competitive... so I will include the into the parts house recommendations at the bottom... (there are a couple of good folks at Sears... I'm sure... I've met 2 (two)).
appliancepartspros.com will also be included...
even though the choke on your MODEL Number...
Current models seem to all be suffix with
an ADDITIONAL 0,1.2 or 3.. after the WTW6400SW...
I believe YOUR NUMBER simply because I have had a couple of occasions to have "parts technicians" squabble (SEARS) with me ... over such trivia.
(Hence the importance of SEARS and their guaranteed fit).
Good luck with that...
Always get three estimates
(which will TYPICALLY eliminate SEARS)...
Comment me back if I missed anything!!
http://www.appliancepartspros.com/whirlpool-latch-wpw10619844-ap6023438.html
Lid Lock Assembly
Whirlpool WASHER LID LOCK Strike Switch Frigidaire Assembly Factory Part...
http://partssellect.com/
1helpful
1helpful
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
2answers
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
I lost Power from a Thunder Storm and now my Whirlpool Cabrio top loader won't open
Thats sounds as if the lock asm is stuck. As soon as the power went off the lock would have de-energized and should have opened.
Too check the lacth for sticking open the top by placing a putty knife in the seam between the top/front cabinet panel at the corners and push in to release the clips that hold the top to cabinet then raise top and see if something appears to be stuck on latch asm.
Gene
What would you recommend for a good super capacity top loader washer? My 15 year old Whirlpool just died. Don't really trust electronic controls, reviews of he top loaders are so mixed, I am unsure. Also...
To be honest I really don't trust electronic controls due to the fact that the majority of the repairs i do on front loader machines has to do with the electronic controls. In my opinion top loaders are more reliable. they get the job done. If you were to get a top loader i do recommend whirlpool, even though i agree that the quality is down. I also like the whirlpool cabrio, its a top loader but has electronic controls. it uses less water and soap just like a front loader. Whatever you do decide to purchase, I highly recommend that you purchase the extended warranty. This way if there is ever a problem, you know that you are covered.
1helpful
How to remove casing from kenmore elite top loader screws are in the rear of washer
Here's a link to a video on opening a Whirlpool Cabrio which is the same as the Oasis which is just a Sears branded version of the same washer.
http://s160.photobucket.com/albums/t200/Zenzoidman/Washers/?action=view&current=cabrio-fixitnow.flv
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
