U-Line Icemaker Logo
D
David Westrheim Posted on Jul 27, 2016
Motor run on noise
Clunk sounds when stopping
"Clunk" sound from mixer while running, now does not turn on at all.
You could take the brush covers off and pull the brushes out and look down the hole with a torch and see if you can see anything unusual down there. Also back cover off and look at the switch, wires and governor. If nothing is noted then you will be pulling it apart looking and testing until you find the fault. Making a clunk sound followed by death sounds to me like something has engaged with the motor armature and the majority of that is deep inside. Here in NZ those things have a 5 year guarantee, if wherever you are is close to still being in guarantee you should get it to a repair agent for repair without fiddling about.
Have a 2004 polaris ATP 500 when turning there's a clunking noise I changed wheel bearings and noise still there ! Checked u joints not really a lot of play in them!
2011 Sportsman 500 Trans Clunk - ATVConnection.com ATV Enthusiast ...
atvconnection.com/.../polaris/343211-2011-sportsman-500-trans-clunk.h...
Mar 21, 2012 - It is really noticeable when wheel is turned when you get on the gas from a. ... 2011 Sportsman 500 Trans Clunk ... You have to figure from the motor to the clutches,then to the transmission,then to the drive shafts,there is going ... 1999 Sportsman 500,slight clunk from dead stop
Feb 28, 2015
Clunk or pop in the steering on an 07 Sportsman 500 ...
Aug 8, 2008
500 HO, rear end noise
Apr 29, 2006
clunking noise on scrambler 500...
Jan 31, 2000
More results from atvconnection.com
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aveo noise when turning and breaking
Sounds like the wheel nuts are not fully tightened on the wheels.I would check that first.Some shops use a "torque" bar when tightening wheels which can result in loose wheel nuts due to rusty/tight/damaged wheel stud threads creating a false torque reading and loose wheel nuts.
1helpful
2answers
Power windows won't work. they are not rolling up or down.
It can only be one of a few things. First if it is the switch it won't make any sound at all when you press the button. If you can hear a sound, then the motor is running. If it has a 'clunk-clunk-clunk' sound to it then the gear plugs in the window motor need replacing which always happens around 10 years old. If you hear the motor running without the 'clunk-clunk-clunk' then the regulator cable has jumped track and the regulator will need replacing.
2helpful
2answers
Frig shutters and makes noise when the cooling cycle shutoff.
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
1helpful
Clunk noise Ruud Furnace
I had the same problem, the motor shaft and bearings were going bad. There was about 3/16" travel on the shaft that the blower attaches to. I replaced the motor myself and it runs nice and quiet. I have had that noise that you describe for over 8 years, but it got real noisy about a week ago. I talked to the maintance department about it where I work and they said the motor bearings were probably going bad. They were right, I took the motor out of the furnace and they took it to a parts store and got me a new one $270.00 for it. It is a special motor due to the fact that the frame mounts bolt directly onto the motor housing. Make sure if you do this job yourself that you take the motor to the parts store so that they can match it up. The guy at the store told our maintance man if it didn't require the bolt holes in the motor housing it would have been $100.00 cheaper.
63helpful
6answers
Rear end clunk in Chevrolet Silverado 1500 pickup
The noise is caused by the axle button being worn out, this lets the axle move back and forth and clunk, this is a unique problem with C clip retained axles, it is a noise issue but will not fail and cause any more damage, in order to fix it you must have the axles pulled and the diff carrier checked for excess wear where the axle retainning C clip rides, if the carrier is ok then replace the axles.
2helpful
Motor noise
You can remove the lower back cover panel and visually see the compressor and fan. Check the mounting bolts on the compressor to see if they are loose allowing the compressor to bounce around in there. You can also "stall" the fan with a wash cloth to stop the blade from turning (it's OK just try not to bend the blades). That will eliminate the fan squeaking as it coasts down to a stop. Better to stuff a wash cloth in while the fan isn't running. Turn the t-stat up to colder to force a run condition for a minute or two then turn the t-stat down and watch the compressor and listen for those sounds again.
Top U-Line Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
