Washing Machines Logo
Bev Brown Posted on Jul 28, 2016
I have hoover HD washing machine drain pump not emptying no blockages no fault with pump cod this be relay in pcb if so where is it located on the pcb thanks
5 Related Answers
Anonymous
  • 82 Answers
  • Posted on Jun 28, 2009
SOURCE: washing machine does not spin
check the brushes on the moter
Anonymous
  • 122 Answers
  • Posted on Jul 05, 2009
SOURCE: Fault with draining washing machine
hi,
verify lid switch function first. you can bypass lid switch with jumper wire. unit will not spin out if lid is open. if switch goes bad it thinks lid is open when it is actually closed
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jul 06, 2009
SOURCE: Model wma58 as soon as the machine finishes it
Probably blocked filter, remove lower rear cover, locate and remove large black hose on bottom of drum, remove and clean filter inside hose.
Please rate my solution.
Thanks.
Rod Wilson
  • 4 Answers
  • Posted on Dec 04, 2009
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 24, 2010
SOURCE: my hoover hnf7148 will not
What you need to do is select a drain only programme you should hear the pump working, if there is no sound, then then it could be a faulty pump, or it is not getting any power, to check this you would need a meter to test for voltage.
How to remove the drain pump from my hoover washing machine
bend machine one side locate drain pump remove drain hoses, screws and pump, replaced with a new one
Whirlpool ADP 9620 dishwasher not working?
Is the machine still full of water? did it drain by itself?
if not, may be a blockage in the drain pump or circulating pump. Can you hear the pumps running when on drain at the start of the program? The machine will not start unless it is fully empty, as it follows a logical series of steps, and recognises when something is wrong - ie full when it should be empty, etc.
Check the drain pump, pump impeller for foreign bodies, and waste hose, the fill hoses and if you haven't done this already.
If not this it may be control pcb, motor or heater faults - but check basic issues first
Feb 02, 2018 • Dishwashers
1helpful
My hoover hnf7148 will not drain all pipes clear as will drain fine when drain pipe dropped to ground level so no blockage have changed pump to no avail have heard this model suffers with a pcb problem if...
2helpful
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Washer not draining , the pump has been replaced and its still not draining , drained water hose in bucket, no blockage, is it the relay?
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
1helpful
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
13helpful
3answers
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Grinding noice
more then likely that the pump has some kind of blockage in it this will cause the washer not to empty fully which when it goes onto spin it will bang about due to the water going from side to side check the pump will be underneath just were the drain hose goes into the washer you will have to strip to get the blockage out once done it should work fine m8
PE235 gets stuck on draining and won't go to spin
what you have is whats called a magnetic pump it should feel jerky to rotate but should be free without locking up, this pump is designed this way to avoid little things getting blocked in it. if the pump is free from blockages and works electrically, then the pump is not a problem, the problem sounds like the motor or the motor control board pcb which is located at the side of the timer (i think on that model) first check the motor carbons for wear, the armature for signs of burning or sparking, then the module for any signs of scorching etc, difficult thing to diagnose without test equipment but you now have somewhere to start from when looking hope i have helped a little
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
