Sharp Ar 5316 Logo
V
Violetto Manila Posted on Jul 29, 2016
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
efen
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 16, 2016
efen
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
9158
Points
20
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
EMAIMO
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 22, 2017
EMAIMO
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1115
Points
9
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
My sharp copier AR-5316, is showing error message  - hap 4 real 2 001-5wqsp0ym3pzn0ijbifnrhyn3-1-0.jpg
Sharp IR 5316 is error code E7 how to clear
Hi Zihaalsan,
Normally Sharp Error Codes are 4 characters. It should be E7 and then 2 more numbers.
The E7 family of codes could be a duplex issue, a Laser issue or a few other options. You won't be able to clear the error code on your one. I suggest calling on a local dealer to assist.
If you give me the rest of the code I can tell you exactly what is causing it.
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
3helpful
3answers
My sharp copier AR-5316 E, is showing error message L4. How do I clear it and solve the problem. Please I need urgent assistance.
L4 is a motor lock if you hold down the start key it should give you a sub code 01 main motor, 11, Shift motor, Make sure all jams are cleared out of machine a jam in the fuser/heater section will cause a moter lock to clear code press key #/P-asterisk(*)-clear key(C) asterisk(*) machine will ask you to enter simulation enter (14) on 10 key pad press start,machine will reset or you may need to press CA key to make it reset. If problem comes back you will need to place a service call.
1I am was using Sharp ARM155 printer/copier. i got the error message on printer that "Error Code [E7-11]. Please refer the user guide". please tell to me how do solve the problem.
E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
1helpful
Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
MCU PWB abnormality
18helpful
3answers
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
3answers
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
2helpful
3answers
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Sharp AR-151
Try this sequence
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "26", "Start Key", "39", "Start Key"
there IS another subcode besides E7 try holding the stop or start or clear key you will probably see some different #'s
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
