CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
SOURCE: LG washer CL error code
LG's 'CL' is actually not an error but an indication that the Child Lock is on ;-0)
To disengage the instruction I have is to press 'temp' and 'eco/rapid' together.
If you do not have a manual you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Please score this advice accordingly and good luck ;-0)
John C
SOURCE: attached hoses and they are
Turn off the water supply to the machine and remove the water supply hose(s) from both the machine and the supply taps (US=faucets).
Check that there is a rubber sealing washer in the each end of all hoses and that each washer is undamaged. If the washer is missing then chack on both the supply tap and on the machine inlet connection as it could have got stuck on those items when you disconnected. If any washers cannot be found or are damaged, then replace them. They only cost pennies from any DIY/hardware/plumbing store.
Reconnect the hose(s) and tighten by hand. If you use a wrench it can overtighten and distort or split the sealing washer. Turn on the water supply and check for leaks, if there are any then tighten any leaking connections a bit more by hand.
Other things to check are for split or damaged hoses (unlikely), split or damaged tightening collars on the hoses, or cross-threaded collars. If there is any doubt about the hoses themselves or the connector collars, then replace them. Also check that the leak isn't from the supply taps themselves. If so, then they either need to be replaced, serviced or removed and refitted to the supply pipes. If you find it is a supply tap problem and you need assistance with that issue then please report back for more guidance if you need it.
Note that there is absolutely no need nor benefit in applying PTFE plumbers tape to the hose connection threads. The washer is what does the sealing, and as the hose collars are plastic they're not going to corrode onto any metal supply taps.
SOURCE: lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
SOURCE: LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
