Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
Posted on Jul 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brother mfc240c init 4F & init 5A
Hi. my brother mfc240c hv a problem . first appearing on lcd init unable 4f . after moving the print head i can made 2 copies maybe more. later appears a new code in the lcd (init unable 5A) and nthg can let it work in spite i check it out and no foreign things in the machine
tks a lot and appreciating your assistance .
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Mar 02, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814588
Points
14613
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2761
Points
This worked for me you just conect you printer to the computer and run this program, may be that windows block this file but just unblock it run it and you brother works.
http://www.megaupload.com/?d=FYUBHTF9
  • Anonymous Jun 26, 2010
    update it wasen't this program what worked with my mfc240c I opened the machine and ceaned the cartridge place, closed and leave it for couple of hours and try again when you start the device set a ink clean up and waka waka!
I have a problem with "brother DCP-J140W" printer, it shown at the LCD "Init unable 4F" i was thinking the problem must be the printer head, can it be repaired or just replace the head ?
Hi
Error 4F means your printhead is RIP, mostly due to bad quality ink, the only one way to fx the printer is changing the printhead but... is that really worth it?
Well, check on ebay.com or isscx.com if you can find your part at a good price!
Best Regards
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
How can I fix DCP-195C unable to Init 4F?
Could be print head or print head PCB problem .
An "Unable to Init. 4f" error on a Brother DCP-350C.
unable to print 4F your printer is need to replace new printer head, this the best solution for your printer
2answers
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
2helpful
2answers
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
3helpful
2answers
Unable to init 4f
Problem with Brother DCP-J125
Unable to init 4f
Norman Weimar
Norman Weimar
k24674
