Sarah, The dehumidifier compressor could be bad, may have lost its refrigerant charge or a bad overload protector, have an appliance Tech. check it and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Dehumidifier is Not Collecting Water
How to Repairing Dehumidifier
Why does my dehumidifier run but the pan doesn fill with water ShopYourWay
SOURCE: I have a Danby Premiere
did you put the plug into the drain hole inside the top of the unit???
SOURCE: Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The
'coil' (a finned metal part that needs air to flow across its surface) may be filled
with dust and obstructions, so no air can move...then no water. There is a
blower motor that must move the air. If it is seized up and not blowing
air...very little or no water. The compressor creates condensation from
air moving across the coil (like the moisture than forms on an ice filled
glass on a humid day) to extract the water from the air. If it's not
working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not
working. If it's real hot air, and the humidifier keeps cycling on and
off quickly, the coil is dirty. Those are the 3 things that need to be
working.
SOURCE: Whirlpool/Gold/Energy Star-Dehumidifier model:
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
