I have purchased recently a Frigidaire Affinity front load washer. The first 3 months of use were just fine. After that, at every wash, I get an error 21 at mid-cycle. I am able to cancel it and restart. The washer suggest to start at 27 minutes. Now, I have the error 21 twice or sometimes 3 times per wash. I finish it with a spin cycle that does not cause any issue.
Sorry, it is an error E20.Sorry, it is an error E20.
AnonymousNov 26, 2007
yes the problem here is that when you try to call the 800 # you get a recording and can't get through!!!! yes the problem here is that when you try to call the 800 # you get a recording and can't get through!!!!
AnonymousJan 18, 2008
I have the same problem and have checked the drain tube to see if it was not draining the water, that was not the problem. I checked to make sure the machine was level, it was. Not sure what to check next.I have the same problem and have checked the drain tube to see if it was not draining the water, that was not the problem. I checked to make sure the machine was level, it was. Not sure what to check next.
AnonymousMar 16, 2014
Frigidaire Affinity gets dr signal at spin cycleFrigidaire Affinity gets dr signal at spin cycle
AnonymousMar 21, 2014
I have a front load Frigidaire Affinity front load washing machine and the LED lights come on by themselves when there is no laundry in the machine this does this all day long every day I am constantly cancelling it so it will go off, what could be the problem?I have a front load Frigidaire Affinity front load washing machine and the LED lights come on by themselves when there is no laundry in the machine this does this all day long every day I am constantly cancelling it so it will go off, what could be the problem?
AnonymousMar 22, 2014
sometimes it will not spin, Ive seen error code F-21 and 5-Dsometimes it will not spin, Ive seen error code F-21 and 5-D
You can't post conmments that contain an email address.
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
I had the code E21 error (not draining) on my 2012 Electrolux EWFLS70JTS0, which I'm guessing is similar to a Frigidaire Front Load Washer. After reading about the potential causes being related to drain or pump obstructions, I decided to try forcing compressed air into the drain hose at the rear of the washer to see if I could push out whatever got into the system. So I moved the washing machine out from the wall, and pulled the drain hose out from its wall inlet. No disassembly required. Then I placed the trigger air nozzle from my compressor into the drain hose that's connected to the back of the machine, and held it in place with my hand so that most of the air pressure would go up the hose and into the machine. Once I pulled the trigger to start the air flow it only took a few seconds to see bubbles appearing in the washer's tub. At that point it seemed any obstruction was now pushed out (where it went, I'm not sure. Somewhere in the standing water in tub I suspect). I suppose it would be just as effective to use a garden hose with water (if you don't have an air compressor), but a little more messy. Anyway, as soon as I put it in "quick wash" mode (which starts with a drain cycle), it drained fine. 100% problem solved! No more error code. And no repair bill!. I just hope that whatever was restricting the drain flow does not find its way back into the system again. It's been a couple of days and so far, so good.
Hello Deena,
Error Code e21 means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
Pull the machine out from the wall.
Then take the panel out in the rear. Once the panel is off you will see the drain pump.
Disconnect the drain Tube between the Tub and the Pump.
Look inside the pipe you will find the Drain Filter.
Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
I understand you are receiving an E21 code on your Frigidaire Affinity washer, model# ATF7000E, and it is not draining. The E21 code can possibly mean that the water is not draining out fast enough. Please check the drain hose for any kinks or clogs. Also, make sure that your home's drain pipes are not clogged as well. This could also be a false code. Try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
Good Morning Friend, this is Z. That's a great question!
If you are getting an error code E21, it usually means that your washer is not pumping out water fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
Hello markramos66 - An error code E21 commonly refers to the water in your washer is not pumping out fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged.Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
You have a pump error - 1. Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2). 2. Start the washer and check for 120VAC at the drain pump. Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
My Affinity washer quit spinning during the rinse cycle 14 months after we purchased the machine. We checked to make sure ithe drain was clear, and we tried changing the size of the loads. Nothing we tried worked. I was not getting any error codes on the control panel. We called a technician out to our house to see if it could be fixed. He diagnosed the problem as the control panel. We called Frigidaire to see if they would help us out with the cost of the repair since the machine was only 14 months old, even though our one year warranty had expired. They stated that they would not cover the replacement of the control panel. After the technician replaced the control panel and tried the machine, it still did not work. He called the Frigidaire tech support to find out why, and they told him that he needed to replace the door latch system, not the control panel. After he replaced the door latch the machine worked fine. When researching this problem online, I discovered that Frigidaire has had several problems with the door latch system on their front loading washing machines. They previously had a class action lawsuit due to this problem. When I found this out, I called Frigidaire to see if they would pay the repair bill we had incurred, even though our warranty had expired 2 months ago. After they contacted the technician that worked on our machine, Frigidaire decided that they would pay the cost of the replacement door latch and the labor fee. We had to pay for the cost of the initial service call. If you are having this problem, I would suggest that you contact Frigidaire. They will require that you have a diagnosis made by a certified technician. According to our technician, the flow chart for the Frigidaire front loading machines is inaccurate, so if they make an initital diagnosis of a faulty control panel you may want to have them contact Frigidaire tech support to double check the diagnosis. Frigidaire may help cover the cost of repair if your machine has a problem with the door latch.
