Question about Daewoo Washing Machines
How to troubleshoot Daewoo washer stuck in spin cycle with error code e2, e9
I have this washer and it was barely used before it broke. So far I have replaced the main board and the pressure level sensor. Now that I have done this, I am getting e2 and e9. The machine sits on spin cycle, door locked and there's a churning sound (like it's trying to do something?) The tub has no water in it, at least not that is visible and it thinks it should spin no matter how many times I unplug and plug it back in. s it that the pump is trying to clear out some remnants of water but the pump is faulty/blocked? I took the pump hoses off, took the impeller assembly off and it seems clear. What now?
5 Suggested Answers
6ya staff
SOURCE:
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: washer will not drain, seems to be plugged
Try using a wet/dry shop vac and see if you can pull water through the drain hose in the back. If you can, duct tape the vacuum nozzle to the drain hose to make a good seal. With the vacuum on, watch the drain hose under the tub. If it collapses, you have a clog somewhere. It may be easier to remove the hoses from the pump, first to see if there is anything stuck in the impeller. It doesn't take much to restrict water flow. If you need to remove the hose from the bottom of the tub, try to get as much water out using the method I mentioned. It may be slow, but as long as it can pull water, try to drain. This will save you from a big mess later. If there is a clog in the hose, all that water will gush out with the hose disconnected. You may want to have a few towels handy. Now...in some models there is a plastic ball valve in the drain hose connected under the tub. This needs to stay there, but may also be jammed with crud. Sand and dirt is notorious for clogging at this point in the drain system. This hose should come off with a simple clamp tightened with a screw. If you go through all the effort and find the lines clear, you may have a failed drain pump.
Posted on Aug 10, 2007
robert samples
  • 1314 Answers
SOURCE: Washer will not leave the drain cycle
ok let me pull up the servic manuel and ill get back to you ok we are all trying to help but takes time ok
Posted on Jan 15, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Posted on Feb 23, 2008
Richard Lew
  • 489 Answers
SOURCE: Drain Cycle Noise
The only way to get into the drain pump is to have the top panel, the control panel and the front panel removed.  You will have to move the washer out of the closet to get the 2 screws holding the top in place.
Posted on Jul 23, 2008
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
Our whirlpool cabrio washer model wtw8500dc0 will start a cycle. It shows error codes E9 F7 what is the problem?
you either have a bad motor or a piece of clothing is stuck between the tubs,open the lid and see if the tub will spin,if not clothes got down between the tubs.also check the wires down near the motor,sometimes the snap inside the casing from the tub going off balance,if there is a piece of clothing stuck between the tubs you pop off the top plastic part on the tub but first you have to get the top of washer off to do this,usually the clothing will be in the back right side,the metal might be sharp on the tub,i use a coat hanger to hook the clothing and pull it out,good luck and hope this helps,go here to see error codes.
http://www.searspartsdirect.com/washer-repair/error-codes/whirlpool-2015-cabrio-top-load-washer-error-codes.html
Sep 26, 2017 | Whirlpool Washing Machines
Maytag washer 2000 series model YMHWE251YL00. Does not finish final spin cycle. Error codes F9 E2. Please help!
If you go to web site for clarification of the codes you will know exactly where to look in your machine. If not finishing spin cycle there may be an issue with the belt drive that spins the drum to remove water.
Sep 19, 2017 | Maytag Washing Machines
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Jun 01, 2017 | Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Hi we have daewoo washing machine coming error E2
Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
Jan 14, 2011 | Daewoo DW500M Top Load Washer
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Paul Bade
Fahr Quad
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
