Print quality down how ti increase
4 Press the arrow down key to select Print Report.
5 Press the Enter key.
6 Press the arrow down key to select TX Transaction.
7 Press the Enter key.
8 Press the arrow down key to select when you want the report to print out.
The asterisk (*) in the message display indicates the current setting.
9 Press the Enter key. The setting for that report is complete.
> If you want to continue the setting procedure for other reports, repeat steps 6 - 9.
> If you want to perform other setting procedures, select End and then press the Enter key.
> If you are finished making settings, press the Reset key. The operation panel will return to the
initial mode settings.
This information can be found on page 7-2 of the Fax System Operation Guide which can be down loaded from Kyocera's website.
