how to answer incoming call? blu Cell Phone ... Please help find the manual for this blu Cell Phone. blu Cell ... i have a blu advance phone and when i turn it on i.
Oct 22, 2015 - how to answer an incoming call - Blu Advance 4.0 L 4G with 4GB question. ... My BLU cell phone is stuck on the boot screen how do I fix it?
You should be able to use your SIM card in any phone as long as the phone is not locked to a network. Whether your calling plan allows data is another issue.
It may be the same as my Cubot GT88.
To use a different one of the preset ones, applications> settings > audio profiles.
, then tap on the picture of faders on the right. And the settings will appear
For voice calls, video calls , and default notification sound. Tap on the one you want to change
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
