My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
Trouble connecting my new Kindle to my wi-fi
Mary, Check the attached links,instruction and guides to get kindle connected, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Can Connect Kindle 5th Generation to Wi Fi
Fix Kindle HD WIFI problem EASY
kindle won connect with wi fi
12 major Kindle Fire problems and how to fix them
