Kenmore 98702 Stacked Washer/Dryer Logo
P
Paula Nathens Posted on Aug 05, 2016
How long is a wash cycle on model 970L97522F0tacked washer dryer
What is the time of the washer cycle on my Kenmore stacked washer dryer
5 Related Answers
Anonymous
  • 185 Answers
  • Posted on Mar 31, 2008
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Anonymous
  • Posted on Aug 11, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 15, 2008
SOURCE: kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Anonymous
  • 12 Answers
  • Posted on Jan 31, 2009
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Anonymous
  • 89 Answers
  • Posted on May 28, 2009
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
1helpful
My kenmore stacked washer/dryer has a wash cycle that can last for 12 hours. it will ultimately finish and clothes will be cleaned properly but it takes long breaks during the cycle.
The time it takes to do a cycle is determined by the washing machine timer. That is driven by a clock motor. This is an older machine so what is happening is that the motor on the timer is stopping and starting. A replacement timer is sold only as a complete assembly. I'm fairly sure you washing machine does the best job in the world in cleaning cloths.
Hope this helps,
Best,
Mark
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Kenmore washer model 417
most time on kenmore washers any of them the lid switch goes bad you can replace it or bypass it,let me know-mike
Kenmore stack washer and dryer
2answers
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Alexander
vince
