SOURCE: xerox workcentre m20i turns off
Sounds like the machine software is corrupted.
Try this first. Turn the machine off, then on back, there is a panel on the back cover with to plastic tabs that will release it. Pop that off and remove both memory sticks.
With the sticks removed, turn the machine on and let it come to ready. Shut the machine off , replace the memories and turn the machine back on, That reloads the machine software cleanly.
If that does not work. Go to Xerox.com, click on support and drivers, enter M10 into the search box, then click on Drivers and Downloads. Once there go to the firmware and download in with the instructions . I think the level is at 3.04 now. follow the instructions to install the firmware.
One of those 2 should resolve your problem.
SOURCE: HP Officejet 7310 All-in-One Power will not turn on
I am thinking that this is well over a year old, but if not,even if it is under warranty,consider the cost of shipping it back VS a new one.
If you could access the power button you could do a continuity
test and see if it is the power button. Then if that is ok, what is it.
I don't believe that the HP site has a checker,so if you did not register you would have to check your receipt. Then you have to get a RMA, but if it is under warrant it might be worth it.
If you have any questions please post back,everyone is more than willing to help.
SOURCE: Power went off and on and now I can't get the MX850 to start.
If you can move the printhead to the center, try removing the inks and the printhead. Try to turn on with printhead removed, if power comes on you need a new printhead, if it doesn't come on the power supply or main logic board is bad.
SOURCE: Epson R320 Service required message
SSC will not reset the R320
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank
You need the power cord which has a polarized plug on one end. The other end (a figure 8 like shape) will fit into the printer. See http://gdlp01.c-wss.com/gds/7/0900005347/01/ip1600esi_us.pdf . Amazon and other sites have replacement power cords for Canon inkjets and inkjet multifunction printers. One source: http://www.amazon.com/Canon-ip1600-ip6600d-ip6700d-Printer/dp/B003XT2LKC .
I hope this helps.
