Clothes does not get dry when operation completed
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
SOURCE: why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure.
This sensor is used to know water level in the tube. It is probable
that your model reports the same codes.
It does not necessary means
a broken sensor you must check the electrical connectors and cables as
well as all the mechanic and pneumatic elements like the hose connected
to the sensor.
It is often clogs with soap and other particles.
Good Luck!
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
