MY washing machine (DEFY AUTOMAID 600 DAW 355) fills with water but does not run through the cycles. If you turn the setting dial it spins but does not wash
I have tried on different settings but the "timer" doesn't turn automatically and it will not wash, only spins
I don't know the model, but most electronics and hvac can be reset by simply turning off the circuit breaker. wait a few minutes and power it back on. I don't think you'll find another reset on it.
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
Possible fault of the program controller unit, the program output to the motor when the cycle is in the SPIN mode must be checked.
Make sure that the output is available, check using a multimeter to confirm. If absent then check the program module to confirm.
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
