I would try another usb cord and wall adapter. If this does not work, you can find out if the tablet is still under warranty. If it is not covered then you will have to find out if it is better to repair or replace the tablet. You probably want to install a case and screen protector on the tablet he ends up using.
SOURCE: new battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
SOURCE: I got my son an emerson tablet and charging port is loose can I use a charging pad to charge it
Hi
You do not say how long ago you got this tablet. If it is less than a year, I suggest that you take it back to the vendor with whom you have the sales contract, as it would appear in this case to be not of "Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Unfortunately if there are no lights on the charger itself there is no way to tell. If you are just getting a blank screen and no indication that the LEDs behind the screen are lighting up or anything is happening at all, you may have a mechanical hardware failure. This could have been caused from water, a drop or some other hazard like extreme heat.
Your best bet is to find a local PC repair shop that services tablets or contact the manufacture and arrange a service ticket.
go to the settings section and turn the handicap settings off
