If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Thanks Lawrence - I found out on ShopJImmy that the LED Driver board is located on the power supply board on this model, so I ordered a replacement.
I already replaced the power board. If the LED Driver board is on it, it still isn't working. Before replacing the power board, the flashlight test did not work. Now it does.If it isn't the T-con board, what else, other than the LED Driver board could it be?
