Toys Logo
Girish sivaraman Posted on Aug 08, 2016
Vahichal power down man tga 33-410 Edc 03082-00
chknnbr Gree
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 08, 2016
chknnbr Gree
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
278
Points
Skin is basically three sorts, dry skin, greasy skin and mixed skin. For skin types that were various various aesthetic products have decided carefully in order to give skin cells with proper nutrition. You-can't utilize all cosmetics about it in case your skin is not insensitive. You must take the skin care expert's assistance before choosing any aesthetic merchandise to your skin. Your skin layer is nourished by all cosmetic products . Sunscreen products form a level around the skin to safeguard you from your dangerous aftereffects of rays of the sun. Healthy products get further into skin tissues to nurture the skin from there.
http://nuvieskincareserum.com/luxia-no-7/
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 22, 2011
SOURCE: COD MAN TGA EDC
EDC Electronic deisel control
03050 After run test, zero quantity
03 implausible
Azrael SRL
  • 11800 Answers
  • Posted on Jun 04, 2011
SOURCE: I have problem with my MAN truck TGA 33.400 It
EDC 03779-10 = Fuel pressure too low in the common rail.
Start by checking the fuel filters and the likes for deposits or leaks. Then take it to a repair shop and have them check the fuel pump itself. Finally they will have to dismantle the common rail and the injectors to check for abnormal wear.
This is a big job and if the pump will have to be replaced, very expensive.
jhnolson
  • 822 Answers
  • Posted on Jul 04, 2016
SOURCE: my man tga tuck show this on dashboard edc 03779-10 what is the meaning
The following link provides the brief explanation of the error codes. The EDC code reported is likely related to the common rail fuel delivery system. It will likely take specialized equipment to diagnose the problem properly only available at a service center.
Hope this helps?
http://www.techtransa.lt/MAN_klaidu_kodai.pdf
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
7helpful
3answers
COD MAN TGA EDC 03050-03
03 implausible
18helpful
2answers
Problems Man cod 03089-05 EDC
EDC 03089 -05
EDC = Electronic Diesel Control
03089 = Charge air temprture sensor
05 short circuit to earth
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
