Can't remove case
SOURCE: Bobbin case keeps breaking after minimal use
Nope...it didn't work...I got the new case...and still keeps breaking needles...ready to throw the machine right out the window...3 floors up...I think they sent the wrong case...and on e-bay...another vendor wants 36.95 for a case...don't think it is worth this...only paid 150.00 for the machine at Walmart...personally...plastic parts are terrible...I still have a Singer from 1953...and it still sews like a charm...but just goes front and back...no frills...but the oldies are better!
Dee
SOURCE: Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
SOURCE: I NEED BUY THE BOBBIN CASE XL 3750 BROTHER SEWING
No problem, go to a Brother repair shop and buy one.
SOURCE: Brother SE270D
brother se270d the spring came off the mechism that come down and threads my needle. On the side of that foot is a hook for the spring and from that point I don't know where the other end of the spring go to! Help
SOURCE: I need to take apart
XR-52 (and probably similar) has 9 screws on the back and bottom that needto be undone - be sure to keep track of which screw goes where becausethey're almost all different. One other screw is under the "nose" piece which holds the front shell to the back - it just needs to be loosened. After you haveremoved the 9 screws and loosened the one I mentioned you start at the bottom and pry apart carefully of course, noticing that the last part comes apart at the top where the three wheels go thru the back shell. In order to take off the front shell you need to remove two more screws, also fairly obvious. Reassembly is opposite order being sure when you get ready to put the back on that you align the three wheels at the top first, then work down to the bottom, replacing all the screws. That's really it - not rocked science. Just be sure not to over-tighten screws going into plastic. Have fun!
