Dell OptiPlex GX280 PC Desktop Logo
d
david Posted on Aug 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brother owns a Dell Desktop computer and suddenly it stopped working. - The Power button light is flashing continuously. - The green light on the motherboard is perfectly on. - The port light where the telephone wire goes and the usb port next to it on the motherboard is blinking continuously. - The processor is not starting. - If I remove the power cord, the lights mentioned above and same for 15 seconds.
Lawrence Oravetz
Level 3:
  • Dell Master 10,558 Answers
  • Posted on Aug 14, 2016
Lawrence Oravetz
Dell Master
Level 3:
Answers
10558
Questions
Helped
2699482
Points
29284
Do the fans run? If not the power supply is most likely bad. Hopefully it didn't trash the motherboard, memory and any installed cards. If you can't hear the hard drives spinning up, then it has to be the power supply
5 Related Answers
Anonymous
  • 3587 Answers
  • Posted on Feb 15, 2008
SOURCE: pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Walter H Boehm
  • 998 Answers
  • Posted on Oct 20, 2008
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Anonymous
  • Posted on Apr 06, 2009
SOURCE: Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Anonymous
  • Posted on May 12, 2009
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Anonymous
  • 551 Answers
  • Posted on Apr 14, 2010
SOURCE: Dell Dimension 9150, flashing orange light on
kindly check your processor. isolate it by using other processor with the same specs.
1helpful
I have a Dell Inspiron ONE 2305 All in One. The power supply tested bad so I replaced it, however the computer still will not turn on. When plugged in and pushing the power button, the power button flashes...
When a power supply goes it can do all sorts of other damage. You will need to get the system tested properly, to check the processor, RAM and drives. The PSU can also fry the motherboard. You could try some known working RAM in place of your own, This will eliminate at least one problem.
My Dell XPS 435 will not start. The power supply lights up green and when I hit the power button on the front, it will flash amber then go back out. The fans start for a second when it flashes but then...
Without a diagnostic meter to check, it is cheaper to replace the power supply. You could take the power supply into a place that sells computer parts and see if they can test it. They fail, especially OEM and they have a lot of complexity to them .
2answers
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
3helpful
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
2answers
Flashing power light.
Have you tried a differnt usb cable if that dos not do it get back with me and I will walk you though checking it out
1helpful
2answers
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Flashing icon at the top right of my Dell Inspiron 6400
The first thing I would try is to get a new power adaptor. You can find a OEM on ebay probably for about $20. Just type in your model number on the search section on ebays homepage.
1helpful
Flashing green light
i loose vga video controller
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
