Washing Machines Logo
A
Anonymous Posted on Aug 14, 2016
Any suggestions to washing machine which works with irregular water supply?
My water supply is very irregular (old house with many apartments), therefore new washing machines mostly cannot get enough water to run the cicle (f.e. 8min is not enough). I used old Indesit model and it worked perfectly, but now it is broken and i need to find new model. Any suggestions?
Bill Boyd
Level 3:
Top Expert:
  • Indesit Master 53,816 Answers
  • Posted on Aug 14, 2016
Bill Boyd
Indesit Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925686
Points
172802
All models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Morning Samsung front loader wf1752 water is spurting out of were detergent is placed under door and now seeping out underneath, have pulled apart pipes, are not split what could it be
There are 2 solutions for this problem, the easiest solution is to turn the tap that supplies the water to the machine down so that it stops leaking, the second option is replacing the dispenser drawer housing, The housings warp slightly over time and allow water to leak out at higher pressures.
Repair old water intake valve bosch nexxt washer
You can take apart your water supply valve and fix it but this won't last long and you'll be taking it apart again soon to put in a new one-so,skip the rebuild and install new-life is too short-cheers Denny
Whirlpool Supreme 80 washer
it sound like the water pump has an object in the housing preventing it from operating, take the back off the machine to get to the water pump and take it apart to clear the blockage good luck eric
1helpful
Aq9l292i not starting
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
Saying water supply not adequate
is your house water presser gone down Re: Jeff
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 • Dishwashers
2helpful
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
3helpful
3answers
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Cold water wash and rinse not working.
check the screens on the water inlet valve and or replace the valve
3helpful
2answers
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
