Question about Panasonic Televison & Video
Panasonic TC-P60GT30. The tv has a black screen, there are no red led blinks, it is a constant red led, and there is an electrical buzzing noise coming from the panel
    Top Expert:
  • Panasonic Master
  • 55,370 Answers
Could be an open internal fuse or power supply failure. The red LED merely indicates power is getting to your TV.
Posted on Aug 17, 2016
Anonymous
SOURCE:
Chi Chu
  • 8457 Answers
SOURCE: I turned on power and red light is blinking but tv
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 06, 2010
Chi Chu
  • 8457 Answers
SOURCE: TV will not turn on. Problem with the Panasonic
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same result.Mean ur tv power supply board have problems and the causes.That the board,where the power a/c plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 19, 2011
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
Posted on May 28, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
Posted on May 26, 2012
jayvalencian
jayval
  • 8 Answers
SOURCE: Panasonic 32 inch LCD TV TC-L32X2 Flashing Red Fault
try to check burnt capacitors...
Posted on Aug 10, 2012
I have a 2011 Panasonic tc-p60gt30. It will not turn on, there is no relay clicking, no buzzing, no blinking light. p board needs replaced but 1is main and 2 sub p supplies. How do I know which one?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://schematicscom.blogspot.com/
Circuit diagrams to many popular brand TVs and other devices are given. You can get details there. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Dec 11, 2016 | Panasonic viera tc-p60gt30 60-inch 1080p...
Panasonic TV, Model TC-P505U50
Not sure if it is Plasma or LCD/LED model.
Check out the codes below
Panasonic TV Blink Codes for All Panasonic Models Brainchamber Blog
You need to verify the Power board for defective capacitors. You can replace the defective Capacitors yourself if you are a DIY person or replace the entire board if you can obtain the part.
Aug 01, 2016 | Panasonic Television Mainboard, TV Model...
My panasonic Viera tc-p60gt30 has 11 blinking LED error code this TV does not have a fan. Could it be the power supply? Is there a place to plug in a fan to solve the error code?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 24, 2015 | Panasonic Televison & Video
The screen is black and red light is flashing
check the number of blinks from the LED. that will tell you which board is bad.
Feb 10, 2013 | Panasonic TC-P65S1 65 in. HDTV TV
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
No power on panasonic tc-p60gt30. No red light on front. Brand new. Is there a power reset button?
This problem cannot be resolved by a reset. The lack of power LED means that the processor is not operating. This can either be due to lack of STB 5V or the processor itself is malfunctioning. Since the set is new return it for a replacement as this problem cannot be resolved without replacing parts.
Aug 29, 2011 | Panasonic 60 TCP60GT30 3D Plasma TV
Televison & Video Logo
106 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
