Its paper jam in Fuser Area, i removed paper jamed and checked fuser well no part of paper inside , but same Issue
SOURCE: grinding noise and jamming
Try to pull out paper transport unit (when open paper cassette,there is green or blue andle on the printer) and check what is wrong.Maybe just something is in improper position.
Also check paper settings on printer and driver.
If you use 80-90 gsm paper-Plain, if You using heawyveight paper(more than 105 gsm untill 200gsm) -Thick.
BR
SOURCE: Kyocera Mita 4230
replace the conveying belts x 3 2ac??? part number and maybe worth replacing clutch 32&35 resistance clutch
SOURCE: Installed upper & Lower Fuser, Turn Copier on saying paper jam 03
its not really a jam, its the cover you have to play with it on order to lock well.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: paper jam in fuser unit
It sounds like the EJECT switch in the fuser has been knocked out of position
SOURCE: kyocera
Hi Ben
Sounds like the roller that pulls the paper through has maybe lost teeth on the roller itself.
1702F33E20 Kyocera Genuine MK 510 Maintenance Kit
Testimonial: "Bear in mind though, ive just put in a brand new fuser... The rollers heat up, but they dont move in order to drag the paper through."
I have exactly same problem with a kyocera P7240cdn. Do You remember how fix it?
How fix it
4201 how fix it I tried to cleaning all exit sensor the jam still there
