I have an ecomow electric mower ELM-1400, 1400W 380MM, I broke the orange lever, been to bunnings ordered the part from special orders, they got back to say not available.
Need orange lever, hight adjustment lever the number on the diagram is number 8, there is no part number
It is an Australian and New Zealand special, whereas we are in North America. A fairly extensive search shows that Amazon and eBay don't have them and the maker tells you to go get spares from Bunnings! Not impressed.
Height adjustment is done at the wheels. May have extra holes or a slide system. Dont know what you have so guessing since every mower i ever worked on has holes or a slide where you have to press a lever and turn the bar to go up or down.
If you are taking about the plastic that attached to the end...most any mower repair shop can help..or just take a small piece of wooden Dow rod and drill a small hole in the end big enough to tightly fit on the end and clue it on..will work just fine...good luck..
In Australia Bunnings are the dealer for Ryobi products.
I have the same one and also need a bag for mine.
You have to order the bag from the "special orders" section as it is a discontinued item at Bunnings.
Unfortunately they told me yesterday (15/1/11) that Ryobi have no stock and it will be May before they arrive from Japan.
The Ryobi part number is 4072241 and Bunnings quoted me $15.20.
Hope that helps.
I'm going to take mine in with me to Bunnings today to see if I can modify a bag from another model to fit. Maybe if you don't want to wait until May you could also try that?
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
