"np" flashing, door is locked and cycle is not complete
DO, FL, LO, LR, ND, OD, SD, DF and NF. these are the error codes for maytag neptune washer! there is no np code, check and repost if needed. God-Bless!
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Yes it is flashing nd. Can I do anything to fix it? Is there anyway to get the door open now that it is locked?
You need to clean the drain, pull out the plumbing find the clog. Or find a local stream. LOL.
Is the drain the flexible tube that is outside of the washer?
Or what do I have to do for that?
What do you have to do for what? Please explain the question
Yes that is the drain hose. You may have a stray sock in the drain pump inlet, which means you must tear the whole thing apart to clear it I think
