We had a bad rain storm last night. this morning the ac was spitting water out the vent. i do not smell freon just water. and it is making noise. the drain plug is on the side not the bottom. could it just be wet inside?
Sounds like the drain is clogged, it usually comes out if the outside of the unit just below the coil in the middle of the back, there may or may not be a hose attached to the front pan below the evaporator, try pressuring it up to blow it out. worst case you may have to remove from the window, disassemble and clean. hope this helps...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
I assume that the toilet flushes and refills with clean water? Check the vent- for debris or critters. If nothing is apparent, stick a hose in it and run water down the vent.
Should have a drain on the unit. Check for ports that have debris in them on the outside of the unit. Clean the debris out and the unit should drain normally.
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
check the filter located behind the front panel it usually snaps out also make sure the drain holes on the out side bottom of unit are not stopped up and that the unit is leaned back slightly for drainage freezing is a sign of low air flow or low on freon the coil actually gets colder when freon starts to leak out hope this helps with your problem
the A/C can also cause this have the A/C checked out because it could be the evaporator and also if the orifice is bad in the accumulator you will get this smell because the freon is not circulating and even when the A/C is not on the A/C compresser comes on when the defroster is on just in reverse
3 places where water could be coming from, The Ground, The venting system or the Condensate. Eliminate each one by first checking the condensate piping and check to make sure it is draining to the drain. Blow thru all hoses to make sure they are not blocked. Secondly, spray with a garden hose the venting system to see if the water is entering the system thru the venting. Lastly, if this happens only when it rains, you could have a ground water drainage issue.
