Need to remove pattern
How To Unlock ZTE Through An Unlock Code
That's how easy it is!
There also other ways to unlock your ZTE device by using a mobile device unlock app (for MetroPCS and TMobile USA subscribers). Learn more about this app here : Everything You Need To Know About How To Unlock a ZTE Device
Zte cell phone unlocking instructions
How to Unlock a ZTE Phone
1.Insert SIM card from a source different than your original Service Provider
(i.e. if you have a Rogers phone, use a non-Rogers SIM card),
2.Phone will ask you to enter Sim unlock pin (NCK code or PUK Code )
3.Enter unlock code
4.Phone will be unlocked
SOURCE: i forgot my unlock pattern for my zte
MyDear Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: need to unlock my metro zte phone
If forget the password to unlock X500, you can refer to the following method, which can reset the phone and erase all the user personal information.
1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display "ZTE", press the Menu key at the bottom of the screen;
3) Choose "Wipe data/factory reset" through volume key
4) Press "Camera" key to confirm the above item
5) Choose "YES...delete all user data"
6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
SOURCE: customers child has patterned locked
In the emergency dial enter *983*987# and your phone will be unlocked and reseted to factory defaults.
take the phone to a phone shop they will unlock it cheep usually £10-20 quid
they will connect it too a pc
and use the makers software to remove the code
you may have to fully factory reset the phone
depending what security it has so you may loose data
without factory resteting
