Question about Apple iPod touch
Why can I only fit 831 songs on my 8 gig iPod touch
  • 1,944 Answers
It should store at least twice that number of songs in mp3 format, and up to 2000 in the AAC format. The best guess at this range is that there are other files taking up storage, the most likely being a few videos.
Use iTunes to check the storage usage, as described here
https://support.apple.com/en-au/HT201656
Posted on Oct 14, 2016
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
8 gigs isn't enough if you want more songs you should opt for 16 gigs or higher. each songs has different capacities. therefore it'll fill up your gigs.
    Top Expert:
  • Apple Master
  • 66,497 Answers
Could it be that is more than you can listen to in a week
Posted on Aug 28, 2016
Tip
How to remove songs from your iPod Touch 2
<p>The second generation iPod Touch, also known as the iPod Touch 2, was in storage sizes of 8 GB, 16 GB and 32 GB. Depending on the model, he may never need to remove songs to free hard disk space. If you find yourself in tight space, or low-end version 8 GB or more 32 GB mode settings, use iTunes to manually manage the songs on the iPod Touch. <br /> <p><br /> <p>1. Hook touch to your computer using the USB device. <br /> <p><br /> <p>2. Open iTunes. The program takes a while to read and display the name of his touch in the source list left. <br /> <p><br /> <p>3. Click on the name Touch the left in the source list. <br /> <p><br /> <p>4. Click the "Manually manage music and videos" box, located at the central, if not already selected. This mode is used for music from your iTunes library once the iPod touch in the library computer. <br /> <p><br /> <p>5. Click the "Music" option in a list of source Tap the left pane. Touch your music will appear in the center pane. <br /> <p><br /> <p>6. Click the number you want to delete. If you have multiple numbers, hold down the "Ctrl" and click on the numbers. <br /> <p><br /> <p>7. Right-click a selected song and click "Remove." <br /> <p><br /> <p>8. Click "Remove" to delete the song (s). <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How to delete each and every song from your iPod touch
<p>If your iPod touch is filled with songs you do not want to hear it or not, eliminating each number is the quickest and easiest way to get a clean slate, so you can synchronize the device with just the songs you want. Although you do not immediately delete all your music from the device will connect your iPod to your computer and use iTunes to delete each number to delete all songs on your device without the songs in iTunes. <br /> <p><br /> <p>1. Connect your iPod touch to your computer and open iTunes if it does not open automatically. <br /> <p><br /> <p>2. Click on your iPod touch in the iTunes window under "Devices." <br /> <p><br /> <p>3. Click "Summary" and click the box next to "Manually manage music and videos" to check one place. <br /> <p><br /> <p>4. Click "Apply." <br /> <p><br /> <p>5. Click the arrow next to the iPod touch to the left of the iTunes window. <br /> <p><br /> <p>6. Click on "Music" and a list of all the songs on your iPod touch to open in the right pane of the iTunes window. <br /> <p><br /> <p>7. Hold down the "Shift" key on your keyboard and click on the top of the list in iTunes and click the last song in order to select them all. <br /> <p><br /> <p>8. Press the "Delete" key on your keyboard to delete all songs on your iPod touch. <br />
on Jul 21, 2011 | Computers & Internet
I have an 8 gig ipod that holds a little over 1,000 songs but I can barely get a litle over 500 songs on my zen. Why can't I get more songs on to my zen? Most of the files I have on the zen are in mp3...
it all depends on how big the mp3 files are and the quality of the file i know that i can fit about 900 songs on 2 gigs but the quality is severly degraded you can try and use windows media player and under the sync options you can set the bitrate that the mp3 files will be 64kbps is the lowest and least amount of space and quality then you can go higher and better quality but more space is taken i try and leave mine at around 128 or 256 minimum but if quality isnt an issue then go low and cram it full
Oct 06, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Wont transfer over??
The problem might be that the USB cable is interupten in the middle. You can buy a new one. The problem could be as simple as that.
Aug 24, 2009 | Apple iPod touch
8 gig ipod songs are cleared, but they are still taking up space
Sometimes you need to restore the iPod even though you've already deleted the content. Below I have posted a step by step for restoring your iPod touch in iTunes. If you are still unable to sync the iPod after restoring please do let me know :)
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
May 14, 2009 | Apple iPod touch
Can't delete music off of ipod nano
Go to preferences in itunes and there should be an option in there saying "manage my own songs" in devices, make sure you ipod is plugged in to the computer.
May 01, 2009 | Apple iPod nano
Connecting Ipod touch 8(GB) to Wi-fi
netgear support software could be bad. The ipod might not be able to read signal. umm try restoring the ipod. then plug it to your computer let it recognize it and then before you add ANYTHING to it, go straight to the setting and put in the router number and everythign and see if it works. I know people hate it but restoring it usually works. Its just simple small virus's that hit your ipod through songs and stuff and it eventually makes everything stop working. So get back at me let me know if restoring it worked.
Jan 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Nov 30, 2008 | Gateway 831GM PC Desktop
IPod Nano problem
your ipod needs service.
Nov 13, 2007 | Apple iPod shuffle MP3 Player
Apple iPod touch Logo
218 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
