Question about Hoover Washing Machines
Hoover optima door didn't lock
Door didn't lock light flashing
Anonymous
SOURCE:
Anonymous
  • 16 Answers
SOURCE: door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Posted on Feb 27, 2008
mumma_1
Debs
  • 903 Answers
SOURCE: Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Posted on Oct 23, 2008
cerikitten
Ceri Hind
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
prem mathew
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
Anonymous
SOURCE: Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Posted on Jul 20, 2010
My clean light is flashing and the lock light is on, on my whirlpool dishwasher. I've tried the reset code of HD/N/HD/N and it didn't work! What can I do?
What is the model? If you take the panel off you can test the control board and controller by unhooking the ribbon cable from the controller to the keyboard. Then close the door. If the pump comes on, it is the control panel, if the pump does not come on it is the control board.
Jun 04, 2013 | Dishwashers
Tip
FRIDGIDAIRE FRONT LOAD WASHER DOOR LOCK
THIS FRONT LOAD WASHER HAS AN ELECTRONIC SWITCH THAT SNAPS INTO THE LOCK MECHANISM. MINE POPPED OUT OF THE 2 CLIPS THAT HELD IT IN PLACE, SO WHEN I CLOSED THE DOOR, THE LOCK LIGHT DID NOT LIGHT AND THE DOOR DID NOT LOCK. HAD ALL KINDS OF ADVICE THAT DIDN'T WORK. UNPLUG THE WASHER, REMOVE O RING AROUND RUBBER BOOT. REMOVE THE FRONT PART OF THE BOOT. THEN YOU JUST REMOVE THE LOCK MECHANISMS, 2 SCREWS IN THE FRONT. PULL THE LOCK MECHANISM HOUSING TO THE SIDE, BE CAREFUL OF THE CONNECTED WIRES, THEN LOOK WITH A FLASHLIGHT. IF THE SMALL SWITCH BOX IS OUT OF PLACE, THEN POP IT BACK IN. THIS PROBLEM STARTED WHEN I WAS CLOSING THE DOOR TOO HARD AND QUICKLY. SO BE GENTLE WHEN CLOSING YOUR DOOR. THE ARM THAT LIFTS TO HIT THE SWITCH THAT TURNS THE DOOR LOCK LIGHT ON AND LOCKS THE DOOR, IS PLASTIC.
on Sep 17, 2013 | Frigidaire Washing Machines
Red sercurity light flashes in my truck
You could try re locking the doors then unlock them. Then open the hood and disconnect the negative terminal on the battery for 2 minutes. Hook up the battery and start the truck. This will flush the PCM's cache and restore everything to its normal state.
Dec 11, 2011 | 1999 Dodge Durango
GE Gas range won't work because "Door Locked" light won't go out
yes the locking lever needs to be replaced, and it also adviceable to still check the internal switch.
Aug 04, 2009 | Kitchen Ranges
Door light flashes, dome light flashes, locks keep trying to lock
My Neon did this.....The door sensors were messed up and i just ended up taping pennys to the little knob.....It was a idea from my co-worker who had a Neon and had the same problem....
Apr 20, 2009 | 2000 Plymouth Neon
Door locked light flashing when door is closed
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
