Our dishwasher is about 4 years old. Works great but now it doesnt want to close. It's locked with the door open and we have tried everything to try to get it unlocked. HELP
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
you did not giver manufacturer, model and year, it is not possible therefore to give detailed info what to do - for future references - do provide these "little" details, telepathy is overrated and usually do not work...
from your description can be several causes of that, one of them is motherboard fault, another will be actuator and third can be mechanical fault within lock or with hinge... make your pick...
First I would run the hot water until hot. Then start the dishwasher on the longest setting with the dispenser door closed( no detergent). Then after about 10-15 minutes open the door and check to see if the dispenser door opened, it should have. Then pour in about 1 cup of white vinegar and let the dishwasher finish. When the dishwasher reaches the end of the cycle open the door and it should be hot and steamy. If not check the heating element. If it is hot this should have cleaned it out, now try it with a load of dishes.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Have the same dishwasher and happens sometimes to mine when the door doesn't close properly because it is hitting the cabinet front. Try pulling up and forward from the bottom of the door when it is closed. if the bottom comes forward this could make the difference and stop the leak.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens. We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
