Its worked flawlessly for several years now, but lately the foam earpiece that connects to the battery and speaker easily falls off. Maybe there is a loose connection? Any ideas?
Maybe the link touch not well, do you want to try this one? Amazon com Bluetooth Sport Headphones YELLWWORS BTE 813 V4 1 Wireless In...
Most headphones (wireless) have a tuning wheel that allows you to find your headphone channel pair to base set. It sounds that while checking your foam ear piece you may have moved this dial / wheel. After locating (probably near volume) the control for tune, place headphones on and slowly move control for tuning. You should hear something move control to strongest signal.
your base also has settings switch for channel helpful if you have more then one pair in house, on different TV. Play with both to find best volume.
SOURCE: headset paired but doesnt function in ventrilo
I'm currently having this same problem any solutions?
SOURCE: I purchased the Jabra BT2035
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
