I want to play movie through usb
Hi, maybe the format is unsupported. How about change the video format so that enable to be played on DAV DZ777 home theatre.
As for convert video format, it is recommended to use the powerful Leawo Video Converter.
The all-inclusive video converter to process both common and HD video converting between all pop video and audio formats. Moreover, this HD video converter also allows you to create 3D movies, upload videos to YouTube, edit videos, etc.
Hope it hopes.
Download Video Converter to Make Conversions Easy and Fast
Sony 3 285 995 11 1 Operating Instructions Manual Page 63 Sorry. You cannot play movies on a USB thumb drive. You can only play still pictures in jpeg format not movies.
SOURCE: sony home theatre model dav-hdx265
hmmm..didn't know you could do that? Do you have the user manual on hand?
SOURCE: how can i play my ipod on a dav-dx150 home theatre
there is a wire that pluggs into the headphones spot on our iPod, it then splits into a red/white cable. i dont know where to get this, but mine came with a DVD player
SOURCE: how do i play videos & movies from a pendrive
The system either cannot play the videos cause pendrive not correct format or videos not correct file type
SOURCE: My sony home theatre does not play movie through
u hv to convert it to mpeg 4 on comp then play it [email protected]
SOURCE: Getting an error display as
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
