I have a Samsung Camera S860. It blinks yellow/green light when I try to turn it on. I've accidentally lost the manual. There are no problems with the lens. Can someone help?
I had a similar problem with this camera. although its likely you have damaged the camera (seek repair from authorised Samsung dealer. should have a 1 year warranty - although you may not be able to claim accidental damage) there is always a chance the batteries are stuffed. i spent hours trying to find out what was physically damaged before realising the AA batteries did not have enough CURRENT to support the camera. gave same symptoms. some new extra heavy duty batteries did the trick.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds. A blinking light can mean something is wrong with the power, not enough or something else. If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold
the 'power' button and the 'play' button at the same time for a few seconds - it
worked for my S730. Good luck!
yes,they have and i bet its all becausu your using regular batteries,you have to use energizer litium batteries.try it.good luck.im a photo technician,and sold digital cameras for 3years as a lab supervisor.and i have the same camera too,its awesome.
