M
Moses Samuel Seyi Posted on Sep 07, 2016
How can i fix c3200
Displaying
6helpful
2answers
Samsung mobile gt-c3200 no display only white light
samsung gt-c3200 on disply, LED of problem
Error code display 00007 in ir 3300 canon copier since i have checked fuser unit thoroughly and changed the fuser flim roll of fixing unit still then the error code display manually and after switch ON...
as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
1helpful
2answers
I m using samsung 3200 but i m facing a problem that i want to know that how to remove clock from display screen.plzzzz....help me as soon as possible.
hi...
If you are looking for User Manual for Samsung Metro C3200, You can find it here
hoping this is the one you're looking for.
If this worked for you , then please vote me.
5helpful
Remove canon copier problem e005 np6330 on display
You will need to replace the cleaning web that rides above the upper fixing roller. There is a sensor that reads the amount of web left... Good Luck
CANON IR C3200
Hi there, your printer is experiencing a shortage due to a lose connection that's located on the backside of the control panel. you will have to disassemble and remove this control panel to find this lose connection. this connection seems to be linked to the power board which explains why the screen turns black.
2answers
3helpful
Canon error displayed on LCD E000020-0160
The developer concentration
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
The fault is with the yellow drum unit, normally replacing it solves the fault.
BLANK DISPLAY
Did you try to adjust the contrct knob on the contoral pannel????
20helpful
3answers
Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
